Version 2.30 Bug Notice
kd4efm
EL98 Florida
PLATFORM: NX-5000 VHF and UHF
SERIES: NX-5000
ISSUE: HARD LOCK with DMR and P25 and NXDN enabled radios.
NOT EFFECTED AS OF THIS NOTICE: NX-5400 / NX=5900
JVCKenwood has been notified and I along with Kenwood, have duplicated the bug where the radio will lock up on zone change from SITE ROAMING to another zone.
keyup in a site roam zone / channel, then switch to a P25 zone (next zone up) and it will hard lock.
This is being worked on and addressed at this time.
Evans
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Version 2.30 of what radio/platform/software/firmware? JVCKenwood makes/sells a giant line of radios.
Jay911
Thanks. I'm imminently taking delivery of a handful of 5400s in P25 form. I'll have to keep that in mind.
kd4efm
EL98 Florida
If you're doing DMR and P25 in 800 Mhz. this is not proven for that line at this time.
If you're getting NXDN and P25 for the 700(p25)/800(nxdn & p25) then you need not worry.
This is with the DMR Site Roaming, and changing to a P25 zone on a UHF 380-470 K6 radio this bug has
been found on.
Jay911
Ok, my plans don't involve either DMR or NXDN at all... it's for a 700 MHz P25 system (and some analog in 800). Guess I'm OK. Thanks!
kd4efm
EL98 Florida
Your in the clear unless I find out otherwise, I have not had any issues with the 5400 and 5900 to speak of.
Sent from my SM-G935P using Tapatalk
kd4efm
EL98 Florida
Update; notified this morning.
Platform: Nx-5000 series portables
kenwood engineers were able to replicate the bug between dmr and p25 zone changing; causes hard lockup.
Patch (next version) forthcoming
efm
kd4efm
EL98 Florida
You are good to go, the 700/800 models do not have the zone change hard lock between dmr and P25.
