Vertex 24ch ftl- 2011 vhf
kb5vai
Hi. Just got a vertex 24ch ftl2011 vhf radio. Have a 9 pin serial cable. Connected to s p4 laptop started flashing cl. Hooked to a 486 25 windows 95 laotop cl wdnt away. Tells me radio should talk to laptop. Load ce5 it only shows a 4 ch model. Cant read radio it goves s com ertor. 9600 n 8 1 xon xoff. Tried chznging to hardware, same.comm error. Wont read or write. It stsrts ftl2011 enabled com 1. Tjoughts?
radiotweester
Oregon
Check the wire continuity between the RJ45 and programming adapter. You could try going from 9600 to 4800baud. Check the manual on how to set the parameters from the default of 4 to 24.
