Vertex 510 antenna
rejeanmartel
Montreal, Qc
What antenna connector does the Vertex 510 radio use ? BNC or SMA or...? I'm thinking of using a Vertex ATL-1A antenna on my scanner, Radio Shack Pro-164....
Thanx
FKimble
Newnan, GA
Well a simple search of the antenna model # revealed the following: Note: The ATL-1A is designed to be used in conjunction with Vertex Standard Low Band portable radios. Antenna base is threaded bolt type. Antenna is tunable. Also - Antenna 30-36 MHz /10.5" Low Band for use with VX-500 VX-510 VX-520 Series Radios. Antenna has fine tuning adjustment for lowest TX SWR.
