Vertex FIF-12 vs FIF-12A??
g8tzl2004
Is there any difference between the FIF-12 and FIF-12A programming box?....note the "A" prefix.
Project25_MASTR
Millennial Graying OBT Guy
Texas
The A is supposed to be a revision though in some cases Motorola has dropped the A revision and post Vertex absorption due to the Motorola PN (which is AAJ23X501).
g8tzl2004
My FIF-12 (as printed on the device) is a Motorola AAJ23X501 (as above)..so is that the equivalent of a FIF-12"A"?
There was an old posting, from Vertex Standard, which said that the SVC 49 alignment software for the VX4000/6000 "now" works with the FIF-12A...which sort of implied that it did not work with a FIF-12 (no "A").
g8tzl2004
Anybody know the pin outs on the 8 pin DIN of the FIF-12 programmer for TXD, RXD and GND?
I am building a homebrew cable to align a VX4000L. Alignment is done using the DB25 on the back of the VX4000 and NOT using the mic "accessory" socket which is only used for programming NOT alignment.
The VX4000L DB25 pin outs are pin 9 TXD (+10K resister), pin 10 RXD and pin 18 GND (from service manual...but note the 10K resister which is in the original CT-88 alignment cable DB25 plug which uses the old serial FIF-8 programmer).
Most of my programming cables which use the FIF-12 are for "2 wire" cloning ie RXD+TXD and GND rather than separate "3 wire" RXD, TXD and GND.
