Vertex standard EVX-70R accessories
N7NGK
Sandy
I am in the process of setting up a GMRS repeater using the vertex EVX-R70 repeater. In looking at the installation manual I see the pin-out for the auxiliary plug on the back. it shows pin connections for audio out, mic in, and PTT. does anyone know if there is a "control head" accessory that would have a speaker and hand mic input? I'm looking for a source or even a part number.
Thanks in advance.
N7NGK
RadioGuy7268
PA
To my knowledge they never made a control head accessory for the EVX-R70.
If you're running in Analog mode for GMRS, you should be able to hook up a Local deskset as an accessory using the backplane connections, and have something like an L3211 MC1000 desk set as a way to locally key & monitor the repeater within 500 feet or so.
Note: the Local deskset is different than a Tone remote, although they look quite similar.
