Vertex Standard VX-354 HELP
mstanford
Need Help programming the two-tone function on the VX-354.
Can you set one of the keypad buttons to go directly to off duty page? if so how do you do that?
Or are you forced to use one of the 16 channels as the page channel?
cabletech
Puget Sound
to the best of the information that I have, there is no button selection that will allow for a channel to be set to turn on/off pageing receive.
You must select a channel to due only this function.
Read the radio, then up top click on signal and select the type you want, then select a new channel enter in the recieve frequency then go to signaling and select signaling.
The program help file will walk you thu this
