Thanks!Vertex CE44 for VX160/180 Series.
never mind. went to my old desktop that has xp. program working now.what windows program do I need to run the ce44 on?
Thanks, I will reinstall the program on my laptop with Win.8. since all my other vertex programs are on it as well.Just FYI, CE44 runs on everything I've ever tried it on. XP, Vista, Windows 7, and Windows 8. If you use a computer without a serial port and use a USB adapter, sometimes the drivers can be an issue as can finding the right COM port, but it will work with just about anything.
for some reason I cannot get this program to work at all. I install it and then cannot find the icon to click to open the program at all. Tried installing compat. mode for Windows XP, Vista, and 8. still nothing.Thanks, I will reinstall the program on my laptop with Win.8. since all my other vertex programs are on it as well.
Picture of the file ce44 after I open it.It's not like most other programs. It doesn't put an icon on your desk top automatically. You have to go into the folder - usually in Programs - and right click on the Application file that shows the little Vertex HT icon. Then select "send to" and send it to your desk top. The icon will then appear on your desk top and you should be all set. Alternatively, you can just double click on the application icon and start the program from the Programs folder. Either way I'll bet the program installed properly, it just doesn't put the icon on the desk top, but that's the way it is.
I looked around on my system, and took a pic of both program file locations so you can see what I see.That's where it puts the data files, and where it will put any radio plugs you program. The actual program itself is in a folder under "Program Files" or "Program Files (x86)", I think. I'm at work right now, so I can't look and see where it puts them. IIRC, it creates a file folder called "Vertex" or "CE86" and puts the program in there. I'll check when I get home tonight. Since it created the data files and folder, the rest probably is there as well. I have the programs here at work, but have them installed on a USB drive, so it's a non-standard installation.
thanks but that's no help at all. lol only "vertex" or "vertex standard" file in my whole computer system is in the C: were is shows the files program and program x86. and under that area of Apps I am only showing my 2 vx programs one for the 2200 mobile and the vx350 program. no ce44.push your windows key then click on programs skroll down to vertex or vertex standard and you will find the progrom.
click on it and it will open just fine.
Nice and easy. very simple
I am downloading software from vertex Website, no disk. but will try again.OK, finally got a chance to look at my home computer, The path to the .exe file is as follows:
Computer
OS C:
Vertex Standard
CE44 for Windows
ce44win.exe
If that's not there, I'd uninstall the CE44 program and try reinstalling it. If it still doesn't work, maybe there is something wrong with the installation disk, if that's what you're using. Try installing it from the Vertex Standard site. You can download a .zip file of CE44. An account is free as is downloading any of the programming software.
