Is there a way to put MDC into a VX-824?
He means the squak, ANI, The noise you hear before you talk or after keying up...
Yes 2 ways
1. The VMDE-200 board Encodes and decodes MDC1200, you have to buy the board and install it on your radio, I use one on the vx-829. It encodes/decodes MDC1200, GSTAR, DTMF. Goes for about $100 dollars well worth it! You can use it as per channel basis also...
The VME-100 board only encodes also very good board.
2. On your radio, you have to update the firmware to the latest, then enable it on the software you use to program your radio
with, easy if you know what your doing... I think it only encodes on the vx-829. On the EVX-539 it encodes & decodes MDC1200.
there you have it!
