Vertex VX-924 Low RX audio
Quickcall
Central New York
I just reprogrammed/updated some channels in a few VX-924 VHF portables. After programming the RX audio is very soft, almost inaudible. This wont change much with the volume knob. The radio key beeps and startup beeps work as normal. What am I missing here? :unsure:
carlos7801
Lawrence MA
does the radio emit any audio at all through the front speaker? What is your Firmware? and also verify if the bandwidth you've programmed is the corresponding bandwidth for whatever you attempt to monitor. This can affect how the radio receives the traffic
radiotweester
Oregon
Agreed with Carlos regarding bandwidth set to W5 or W4. The only exception to N would be Ham or Marine or WX.
You can check to make sure you don't have AF MIN VR assigned to a button.
Pitch shouldn't lower audio, but if it's enabled you can try disabling too.
Common, Key Function
Quickcall
Central New York
The radio beeps as normal and adjust with the volume. I have found the the TX audio from the radio is also very low. I don't have it in front of me but I believe they are FW version 1.35 and programmed with the last version of software. Bandwidth is all narrow as it should be for what is being used.
carlos7801
Lawrence MA
maybe a firmware upgrade may solve the issue however you'd need to buy some OEM cables if you don't posess them already. FIF-10A or 12A works, CT-108 and you're good to go! Typically anything ancient that acts funny on me 8/10 that does the trick also.
Check your bandwidth settings for each channel.
Low receive audio often means that the radio is set for WIDE and the transmitting radio is using NARROW
