Vertex VX-P820 ctcss/ PL tones dont exist
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
i am not able to find on option to select a CTCSS Code on any personality on the programming software.
the majority of tabs is for P25, then a few other options down the line. i am uploading a image, i removed the p25 tabs to shorten the sub
83366
SirJ
Menu>View item>Sub Tone
Ensure it is checked
thank you.
Question, i am sure there will be more to follow as this is a whole new platform to me.
Why is field program grayed out under the Common menu? I thought this radio was able to do field programming ( i do have a hunch that it is nothing like Motorola, EFJ, BK FPP etc etc)
radiotweester
Oregon
IIRC you have start the application in dealer mode to see some of the greyed out options. Don't recall how to do this, I am sure it involved starting the application with a switch.
modify the program shortcut to end like this \CE76Win.exe" -f
or use Windows Enabler V1.1 for access to EVERYTHING greyed out
radiotweester
Oregon
thank you.
83429
SirJ
Ok I'll try that.keep in mind the software that came with my radio is called ce106talon. I have not heard of that version before. I can buy ce74 if need be.
Ant9270
The Green Weenie
Did you buy an 829 from Sunny in Colorado? It appears to be a “proprietary” software. Had to get it when I bought an 829 from them to play around with. I believe you also have to have a specific version of the VX CPS for -F or -manu to work and access the grayed out fields.
SirJ
off eBay from rickthompson.
see my last reply.
trumpetman
Charlotte, NC
Those radios have special firmware that disable some standard features to make room for other special features. I believe these were old radios in use by the secret service or some related branch of diplomatic protection based on the "WHMO" opening screen and the non-standard OTAR capabilities.
Ant9270
The Green Weenie
see my last reply.
Yeah, those came from Sunny. They indeed were federal radios that were liquidated, the above post is correct. They got rid of “business consumer” features, and focused more on Crypto and P25 capabilities.
Ant9270
The Green Weenie
Also, just so you know.. CE-59 and CE-74 will NOT read or write on this particular model VX-820 series. It’s a shame as the talon software is extremely limited, but it gets the job done.
SirJ
Yeah, I figured that. I ended up with a copy of ce74. Sure enough it does not work with the radio. At least it's programmed up and works very well.
I'll wait till something pops up on a vx p924 or find another vx-p824 that is not a exfed rig
twl911
Could someone who has programmed or used one of these ex-fed radios explain the limitations of the 'talon" version of CPS?
Considering purchasing one as a pocket sized ham/PS scanner due to size, if user features are overly limited I just continue to use my tk-5220.
trumpetman
Charlotte, NC
What features are important to you and maybe we can let you know if the radio is capable. The only thing I've noticed so far is trading quick call paging for OTAR capabilities. All the usual features seem present otherwise but I'm not very familiar with the bells and whistles Vertex offers.
twl911
Mostly, ability for scan list(s), and modify on the fly(add delete).
I've never really understood "fully" vertex scanning. Always been a Motorola user, but have recently taken a liking to Kenwood.
SirJ
one thing i have not found on any of these p820, p920 series is in the brochure it states you can choose from i believe 7 RX LED lights. There is no setting in the software for that, the only way to see if the light actually has differnt colored rx light is to turn the radio on while holding the lowest side button, than use the channel knob and i have 14ish different colors
btw FPP mode there is no option for that setting either.
I found this on the other site:
type C:\Vertex Standard\CE76 for Windows\CE76Win.exe/f
The clone editor will launch and FPP will now be enabled
other options are
/m (Maintenance Mode)
/e (Engineering Mode)
/d (Depot Mode?)
Again this doesnt work on all CE versions, and all modes might not work on any particular version either, but you can use these methods to bypass passwords, edit S/N's, enable other features, and to go OOB.
The only "Trick", "HAck"/ Mod that works is -F
which enables FPP. :(
I was thinking if these radios are now EOL, they should offer like $199 which gives you access to all latest and last firmware, and be able to enable or disable options or heck even use OOB. EFJ supports hams and allows WIDEBAND options on their VP600 series. ( i have the VP600 and, vp900(vhf 7/800)
twl911
I ended up buying one from Rick Thompson.
I actually see this being used more than my Moto and Kenwood P25 portables, and even my ex560 for analog only. It's tiny, lightweight, and so far has excellent battery life.
I've found the scanning to be similar to my multi group kenwood's. With additional options I have yet to master.
MTS2000des
5B2_BEE00 Czar
I got one from him too. It's got pretty decent audio for a "non-Moto" P25. I run a mixed mode Quantar and this sings through it. Has pretty decent sensitivity too. Nice small form factor. For the price, it's a "for real" radio at a "school bus" (DMR) radio price with superior audio and a ton of zones/channels. Does pretty good on analog too. Not gonna replace an APX, but if someone is looking for a low priced way to get into P25 VHF, this can't really be beat. Same price category as XTS3000/Astro Sabers, which are ancient, require an older Windows XP/Vista PC and not obtainable (legally) CPS, and those radios are huge bricks compared to VX-P series.
