Vertex VX160V Repairs - Cue Up Shutsoff
cuedup
Hey All,
Just wanted to see if I can get some pointers on where to check on the board for my issue. I was able to get a copy of the board schematics.
I'm using the VX160V normally and it will turn on with a fully charged battery and listen without any issues. When I attempt to cue up the radio resets. I've changed out batteries for known working units and the issue still occurs.
Thanks in advance!
radiotweester
Oregon
First thing I'd check is current draw on TX. I know you said the battery was good, but a 7.5v multiple Amp powersupply, as it's a portable you should be safe using a multimeter to check current draw, and Wattmeter with a ~10W dummyload to check output power (if any).
If you search online, the service manual is posted a lot of places.
