Vertex vxr-7000 UHF configuration LOST
jellyspapa
I recently took down our repeater at work to clean it up and back-up the configuration. Well, it cleaned up real nice...looks new.....but I should not have tried to do any programming work after being up for over 24 hours straight! Anywaz...
I hooked up the programming cable, loaded the ce27 for windows software and proceeded to UPLOAD to the radio instead of downloading from the radio first!! Now it is defaulted to a default setup that is worthless. I have never programmed one of the before..(I am a Motorola guy)! Anywaz....does anyone have a config file I can have to at least get me started back where I need to be. Before it was on the following setup frequency:
recv: 463.400 xmit 468.400 PL 183.5
Please HELP!!
PACNWDude
Vertex CE-27 Manual for VXR7K repeater.
We took our VXR-7000 units offline a while back, so I don't have a configuration. Vertex no longer has this manual on their site for download as Motorola end of life'ed them recently. But here is the manual that walks you through the programming.
  • vertex-ce27 manual.pdf
jellyspapa
The downside of it is on page three (3). Bottom of page........
Important Note!
Before creating the program data via the CE27 programming Software, upload the current hardware environment data from the repeater.
This seems to be my problem....there are some settings that I think are not configured correctly from my scratch setup that is causing me issues. Is it at all possible you can bring one of your repeaters online and get those settings for me? Care to sell one of them? I'm really stumped!!
PACNWDude
VXR7K configs.
I have two configuration files, one for uhf and another for vhf. The company got rid of the repeaters a while back. PM me and e-mail address and I can send them on. This site will not let me attach .rpt DOS files.
jellyspapa
I think the values in the enviro settings need modified. Those numbers make no since to me,
PACNWDude
VXR7000 end of life.
From my local vendor, they are pushing people toward the MotoTrbo repeaters, as the the Vertex VXR-7000 was only analog. My company replaced VXR-7000 repeaters with XPR8400's a few years ago.
They work very well and even though the power went from 100 watts to 50 watts, then end user has had no coverage problems and our gear was mostly plug and play.
jellyspapa
Hhmmmm.....I can"t get the windows version to download my modified freq settings. It says I must upload first....well. Did that, loaded my saved rpt file and tried again with same message.
I know I can do this in DOS version, but was hoping I could do it in windows version.
