nevesjerry
Hello to all. I had a R F Systems GMDSS, Vertical magnetic transfer passive antenna which was manufactured in Holland. This antenna was real good on general coverage, i.e. 500 kHz to 30 MHz . A wind storm knocked it down. Can’t see any physical break on it, however when I connect it to my receiver the signal goes ON and OFF with slight bending of the unit. The antenna is about 7 feet tall, however it flexes some what. Apparently there is a helically wound wire inside and tightly packed with sealant, plus is it uses Magnetic Balun. At bottom of antenna there is a SO 239 for the coax. Purchased from Universal Radio years ago. Are there any members that may have one of these for sale? I really don’t want to dig into the antenna, unless I had an X-ray to see where the break would be!!!! If indeed there is one? Any suggestions would be appreciated. I live in Santa Cruz, California.
Jerry Neves, KA6POZ. Thanks so much.
