Ok, lets see what we can do here. You are in Tillsonburg, so your closest Fleetnet sites would be Aylmer or Woodstock most likely.
I will cut and paste from the 'Programming Your Pro-96 For Fleetnet' sticky with the numbers you need:
These first steps setup the bank you are using for Motorola trunking, and set the specific trunking tables that the radio needs to follow Fleetnet properly:
- Select a channel in the bank you wish to use for Fleetnet (typically the 1st channel of the bank)
- For this exercise, lets use bank 0. Hit MAN, then 000 ENT. That will take you to the first channel of Bank 0
- Press FUNC TRUNK
- Press the MODE button to select Motorola
- Press FUNC 2
Enter 141.015 as the base, followed by ENTER
Enter 380 as the Offset, followed by ENTER
Use the UP or DOWN buttons to adjust the Step size to 15.0 KHz
Press Enter to store the settings
- Press FUNC 3, then use the UP or DOWN buttons to set the 3600 CC Mode to TABLE, followed by ENTER
- Press MAN to exit the trunk settings
Now we (you) will enter the control channels (lets enter both Aylmer and Woodstock):
Now press PGM and enter the primary control channel for Aylmer:
- 142.245, then ENTER
- Press MODE to set the channel to MO
Now enter Aylmer's alternate control channel
- Press PGM again (scanner should move to the next channel) and enter 142.605 then ENTER.
Now enter Woodstock's primary control channel
- Press PGM again (scanner should move to the next channel) and enter 142.260 then ENTER.
And Woodstock's alternate control channel...
- Press PGM again (scanner should move to the next channel) and enter 142.530 then ENTER.
You may also want to try the Simcoe site... depending on your actual location and type of antenna it's hard to say which of these sites will work best for you. If you want to enter Simcoe as well, just keep going with the process you just did, and enter 142.725 and 142.440 as the primary and alternate control channels.
At this point you should be able to hit scan and hopefully start hearing some activity (make sure you are scanning bank 0). If you hit MAN then step thru the channels you just programmed hopefully you will hear the control channel grinding away on at least one of them. Give them a listen and you should be able to determine which one you can receive best. Once you have the radio scanning you can start storing and tagging talkgroups.
I don't know if you have a programming cable or not, but all of this is a snap if you do. A programming cable and a copy of Win96 make life much easier
If you have any problems here let me know and I will try to help you out as best I can. I don't have a Pro-2096 but I do have a Pro-96 which is essentially identical in operation.
Good luck!
