Vestavia Trunking
http://wiki.radioreference.com/index.php/Motorola_Type_II
With all due respect.... there is nothing to alter.
Step one is to have the control channel(s) programmed into your scanner. Control Channels on Motorola systems sound like a diesel engine running. If among all the frequencies you have programmed, you do not hear such a sound, you will not be able to trunk-track with your scanner. Scanner should be prgrammed in "Control Channel Only" mode in Uniden scanners. Radio Shack refers to "Open" mode I believe.
Program the talkgroups as you've done, lock out or keep active those of interest and you are set.
Vestavia has gone to a Type-II system. That means talkgroup id numbers will read as the following examples: 16, 43220, 592, 1088, etc. Type-I talkgroup numbers (such as 101-4) will not work in a Type-II programmed scanner.
Now....how do we go about learning the Type-II talkgroups???? Not so hard. Once you are programmed for Type-II Moto trunking, run the scanner in "Search" or "Open" mode.
You will receive all talkgroups. Now by listening to the radio traffic you can often tell if you're hearing police, fire, public works, etc. Please make note of the talkgroups you want to listen to such as fire.
Post back what you get and we can get those talkgroup id numbers posted to the RR-database.
If you have any other questions, please post or write to
julian780@bellsouth.net
** Please advise what scanner you are using - that may help w/ instructions for you. **
Best Regards,
Julian
