gregrae
I have a Unien MC535 VHF Marine Radio
Transmitt Frquency Range 156 to 158 MHz
Receiver Frequency Range 156 to 163 MHz
The aerial on the Boat is 2.350 Meters from tip to base. The winding from the tip down is 533 mm in length befor the wire goes into the whip aerial.down to the Coil at the base of the aerial.I kept the coil as shown in the attachement.
I replaced the insulation wirer from the coil to the tip rewinding the wirer all the way to the tip.
as the existing wirer insulation was breaking off. Do I have to SWR in the aerial.
The Coax has to be replaced but I do not know what length to make the coax as there is a joiner in the section of the wirer.that has corroded away and I want to remove the joiner.(I have baught a length of coax..Can I replace the Coax with a shorter length.
Where do I solder the screan wirer and the Ceter wire of the coax to the coil as the 8.2 uf ceramic cap is solded to the center taping of the coil.as shown on my sketch.
I will place pictures to help you out
