Most Radio Shack and Uniden oem rubber ducks end up in the drawer. How about putting it to use as tuned airband whip?
This mod is nothing more than tightly wrapping about 21 inches of wire alongside the duck, and for eye-safety, wrapping a little loop at the end.
This mod relies upon capacitive coupling to the original helical whip, and while good for airband, is fairly narrow, so it is NOT a good substitute for other vhf services above airband, even if you try to cut it down further.
Here's a shot of the bottom of the duck, with the #12 house wiring taped alongside. Blue painter's tape was used so there would be no messy electrical tape goo left behind when it is removed. Leave a little space between the top of the bnc connector and the wire. Pictured is a Radio Shack oem duck easily identified with the two grooves. I started the wire just above the two grooves.
The length is not exactly critical as anywhere from 20 to 21 inches will do, but don't stray too far beyond this.
