RayK said:
If you use a mag mount behind the lightbar it will affect the radiation pattern, would probably make things worse. Try to see if you can mount the antenna on the lightbar??
Which is usually aluminum (ours are) and poorly grounded.
Also a bad idea.
The cheapest fixes to test are:
Buy and cut a 5/8 wave vhf antenna. Any good quality like Maxrad or Antennex.
Buy a COMMERCIAL quality mag mount with decent coax and try it on your roof.
The antennas on my fire trucks are mounted aft of the lightbar, nmo mount
drilled through the roof.
California Highway Patrol runs the same setup on low band. Aft of the lightbar
nmo drilled through the roof.
Sounds like you are mostly rural and want to keep your signal near the horizon.
Go for a 1/2 wave or 5/8 wave gain antenna first and give it a try.
I've gotten some surplus Antennex stock on Ebay pretty cheaply. New in box. You just
have to set up a search.
Trunk mounts suck for pattern.
BTW what are you using for a radio ?
