VHF FM Maritime Specific VHF Antenna Recommendtions ?
BOBRR
Boston, MA
Hello:
Could anyone recommend a Specific Brand/Model antenna that would fit in my
attic, and cover the Marine VHF fm channel freq's only that they are very happy with ?
I need a decent amount of gain, as am a fair distance from harbor, so this would
necessitate a very directional type, I think, to enable it to have meaningful gain.
Thinking of a Yagi or a Log Periodic type, probably.
Would not need to be omni, therefore, as it would always be pointed towards harbor.
Anyone using any that they particularly like ? (around $ 75 max.)
Thanks,
B.
BTW: would it violate any rules to post this also in the antenna Forum ?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's considered a no-no to cross post - but thanks for asking.
AFAIK I've never seen a marine-band only Yagi or LP; it's an interesting question. Grove sells their Scanner Beam, and DPD Productions has something like it as well. Check our Scanner Antennas wiki for the links. Depending on your terrain, if you're a good distance from the water, you're going to need whatever you buy to be mounted up high....
73s Mike
k9rzz
Milwaukee, WI
I guess you've already searched for commercial antennas without much sucess.
I see two options:
- Build one (not that hard)
- Modify a 2 meter beam. Since a 2 meter antenna is going to be longer than what you need, you would simply shorten the elements to what's needed for 156.8mhz.
http://www.echolinkradio.com/antenna.html
That might be a good way to to actually since you'd have commerical quality, cut specifically for your application.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hmmm...wouldn't you also need to shorten the spacing between the director/reflector and each of the following directors as well? 73s Mike
