Vhf help
rcfd34
Dakota IL
Just got a kenwood tk 7180 vhf i need an antenna for my 01 tahoe will be running freq in the 154 to 159 any one have any suggestions dont mind drilling if i have to looking to spend no more then 60 to 70 bucks so used new dont matter dont really no alot about the antennas dont want anything with a super long whip would like it under 16 inches if possible thanks
n9mxq
Belvidere IL
Any quarter wave NMO will do decent for you, but a 5/8th wave would be your best bet. But you'll have clearance issues. I recommend Larsen with the NMO mount. I've had one for years, and have beat the living snot out of it and it's never failed.
A quick Google search will find them, or a vendor for them.
n9mxq
Belvidere IL
With that size of vehicle, unless you go to a tailgate mounted antenna, you're pretty much stuck with the 1/4 wave.. They're easy enough to install and tune. Just not a lot of gain.
Get one, and put it as close to dead center on the roof. If there's a light in the headliner in that general area you're set. Pop the light out, drill, feed your coax to the radio (the tricky part). Tune the antenna and you're all set.
rcfd34
Dakota IL
Yea i have no idea how to tune lol im all new to this radio stuff i do have a light but cant mount an antenna there theres a lightbar in the way
n9mxq
Belvidere IL
Well, you're in Ridott. I'm not all that far away. You get the mount and antenna.. and I can help you out with the install and tuning.
How's that strike ya?
n9mxq
Belvidere IL
Belvidere. Go to eBay, or Amazon. Do a search for 3/8 nmo mount. Then search for VHF NMO Quarter wave.. They're dead simple antennas, and hard to screw up even for the cheaper manufacturers.
rcfd34
Dakota IL
Ok sounds good im looking at some of laird ones i no my uncle always said they were good ones he use to be big in the ham stuff and radios
rcfd34
Dakota IL
Now does it matter what size coax it uses is it like the satellite cable they run in house like rg6 or what
rcfd34
Dakota IL
Ok cuz i was gonna say if u can use rg6 i got all kinds of that and all the tools to make it w.e length and strip ends lol
n9mxq
Belvidere IL
RG6 is 75 ohm coax, RG58 is 50 ohm.. Your radio wouldn't like 75 ohm for long..
rescue161
KE4FHH
Hubert, NC
I thought that too, but out of all of the ones that I've had, none needed tuning. They were all flat across my entire range. I swept them with my service monitor and the return loss was very good.
rescuecomm
Travelers Rest, SC
I ran my lightbar, 100 watt siren and 50 watt radio off of a single #6 wire that was fused 50 amps at the battery. Never had a problem with it. The 100 watt sirens will pull 15 to 18 amps by themselves, so you will need some good wire. I get my wire and fuse components in the car stereo shops. They have everything you need for a power hungry installation.
Bob
