VHF ht1250 ls + MDC on convention and not trunking
JMR3865
Monmouth County, NJ
Im trying to get a vhf ht1250 ls + to do MDC on the conventional channels. The conventional channels are locked out for MDC but I can enable it on the trunked channels (in which I have none)
Help is appreciated.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
You will have to provide us with the model number. Some of the Pro Series radios have some limitations.
It would also be helpful to know what version of the Pro Series CPS you are using.
Search tags: The Professional or Waris
Series of radios includes:
HT750 HT1250 HT1550
EX500 EX600 EX560 EX650 PR860
CDM750 CDM1250 CDM1550
HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with HVN9025 CPS.
The last version of the CPS released before the
product line was discontinued is R06.12.09.
If you need a blank codeplug, there is a folder
full of them, one for each possible model
number on your hard drive. The folder is in
the Program Files where your CPS is installed.
It is labelled SAMPLES.
Skypilot007
Medford, NJ
I have found typically the LS models of the HT and CDM radios do not have MDC enabled on conventional channels, at least all the LS radios I've had my hands on. I suppose the reasoning behind this is that they were mainly used on trunk systems which usually do use MDC if at all. In the future stay away from the LS models. The non-LS radios seem to always have MDC and other signaling systems enabled and have many more channels available to program.
You can convert the LS radios to non-LS but that's a hole different discussion.
SteveC0625
We have 3 CDM1550LS+ radios that do MDC just fine on conventional frequencies. Like I said previously, the model number will tell what's what if the OP will provide it.
JMR3865
Monmouth County, NJ
Thanks. I will get that information. I didnt purchase the radio as Im not a fan of the LS models due to these reasons. How hard is it to convert it to a non LS model?
