Here's something I built (with a picture included) that is mostly of interest to indoor / attic users.
I adapted an HF quarter-wave sloper, or "half sloper" for VHF use, and instead of using a grounded tower, I faked the vertical section with chokes.
Half-slopers are vertically polarized antennas, and have some gain in the direction of the slope. Mine definitely does.
1) Attach a quarter wave (234 / freq mHz * 12 = inches) of wire to the center conductor of the transmission line. Here, I used the center conductor of an F-chassis connector to solder to, and screwed the RG-6 into the chassis connector. Nothing is connected to the shield.
This wire slopes down towards the ground at a 45-degree angle. Be sure you don't short it out to the braid when you bend it downward. If you need to, you can support the sloping wire with cord, dental floss (no kidding!) whatever to maintain at *least* a 45-degree downward angle. You can bend it downwards even further, perhaps 60 degrees downwards max before things start to fall apart, as the impedance drops when you bring the sloping wire closer to the vertical section.
(antenna height, angle of the slope, element lengths are all tunable for transmitting duties that need absolutely low swr.)
2) Hang the top of the coax feedpoint near the top of the ceiling, rafters, eaves, whatever.
3) At the quarter-wave point down from the end of the coax, (234 / f Mhz * 12) I attached about 6 snap-on RF chokes (RS #273-0105). This tunes the common-mode of the coax to emulate a quarter-wave element. Forget about any sort of "velocity factor" compensation, as VF only applies to the differential-mode, or inside part of the coax. Yes, there is a very small amount on the outside due to the jacketing, but for rx-only we're starting to split hairs.
Compared to a full-sized vhf dipole, this really saves a lot of space up in the attic, and the feedpoint being at the top helps keep the antenna further away from attic clutter.
It was resonant in the air-band when I used 22-inches for both the sloping wire and the start of where the chokes snapped-on. However, I'm using a short run of 75 ohm RG-6 and my SWR meter is designed for 50 ohms so very precise measurements are off. The scanner likes it just as much as my dipole however, although now I have some directivity and a bit of gain.
I don't know how to model a ferrite-choked transmission line used as an antenna element in EZnec, but it does seem to be holding to the textbook descriptions for HF half-slopers.
Note that I tried using a separately cut quarter wave wire attached to the shield at first, but the system was just too unstable on the swr meter, and I didn't feel like devoting my life to it. So on go the chokes instead.
Ok, it isn't a world-beater antenna, but it might be a nice alternative if you need the features.
