Hi guys,
If you really want the full monty go for Antenna Specialists commercial antennas. The Lo Band model is a base loaded 1/4 wave and the VHF Hi Band is a 5/8 wave transformer fed, they all look alike. ASP sells an NMO adapter kit so with that mount you can use Motorola antennas and others along with the ASPs. Band specific antennas cut for the frequency in use are the very best, but adjusted for the center of the band they work exceptionally well on receive across the band in use.
BTW, permanent mounting in the center of the vehicle roof is best, second choice on the trunk lid, third is the trunk lip.
Oh, the frequency range is marked on the base coil and most can be used on nearby ham bands and some cover the bands, one covers 11M CB. Just select the proper coil and trim the whip according to the frequency chart. I had to extrapolate one for 6M but ended up with a 1:1 SWR in the FM portion of the band, perfect.
