VHF-lo monitoring in GA
rayvelcoro
While organizing and updating my frequency lists, I noticed that I do not monitor a single VHF-lo frequency at all. Are there any 30-50 Mhz signals that I'm overlooking? I scan the metro Atlanta area mainly and visit central South Carolina from time-to -time.
RFI-EMI-GUY
VHF-LO Itinerant frequencies .
27.49 Base or Mobile 10.
35.04 Base or Mobile 10.
43.04 Base or mobile 17.
(10) This frequency will be assigned only to stations used in itinerant operations, except within 56 km (35 miles) of Detroit, Mich., where it may be assigned for either itinerant or permanent area operations (i.e., general use).
(17) This frequency will be assigned only to stations used in itinerant operations.operations (i.e., general use).
Also
46.850 FM Military SAR Frequency
gh6406
Dalton,Ga
If you use ULS Search, it will turn up over 200 licenses for low band (30 to 50 Mhz) in Georgia. I am not sure how many are still in use.
RRR
OFFLINE
USA
I remember years ago, the Ga. EMA (I think it was) would do a weather thing on 45.56 (I think?) and it could be heard 80 - 100 + miles out from it's base in atlanta.
This was early 90's.
I haven't had a good hit on low band (aside from CB stuff) in years. 42.020 was a good one back in the day.
N1XDS
ÆS Ø
Anyone have a list with the active frequencies for Army helipcopters? Yes, I have scanned the 30-48 frequencies and never heard anything.
p1879
Try for Ft Hood TX with range control on 30.50; local dusk/sunset time in Ga. will frequently provide a short window there. The excellent mil low band loggings found in RR can put you on to some action. Get a used scanner cheap, make a low-vhf dipole or use a cb vertical, and let about 100 of those mil logging frequencies run and on some days you should have results. If you had a BC-780 you can chain together a bunch of search banks with the "normal" --there are exceptions-- mil low band ranges, about 5 common ones if i remember, like 40-42 mhz, for example. Some real cheap handhelds once had the search multiple frequency-bands option, a Bearcat 30 Channel HH I once had excelled at that.
krokus
Southeastern Michigan
Have you been following this thread?
p1879
Glad we got to re-visit those cool lowband vhf logs. Looking over them confirms an error I made: 30.50 mhz is Ft Sill, and the mega-signal from Ft Hood is on 30.450. Their training schedule and range use could be modified right now, so they may be sporadically active. There is a lot of helo traffic on low band; lets hope the use will hold up as we enter a period of more favorable reception....eventually.
N1XDS
ÆS Ø
Do you guys and ladies use a pre amplifer when listening to the low band frequencies in a different state?
p1879
I never did but had 9913 coax and a high antenna when i was more active at lowband dx. When conditions are good, a handheld with an extendable whip can do wonders if you are on/near water somewhere and away from noise.. Few multiband scanner antennas do much on low vhf. Even the old favorite scantenna or CM 5094 models cant compare with 10/11 m vertical, fan dipole, etc. where elements are long enough to capture some signal under weak conditions. There are some people here who can also comment on mil-surplus antennas, of interest to many of us.
N1XDS
ÆS Ø
I have a DPD Productions Omni X VHF/UHF Military antenna which does pretty well on VHF and UHF just haven't had any luck on the low band for the Military.
GMB951
Cumberland Co,NC
I also have one mounted about 30ft high have monitored range control,military air units and ground units off Fort Bragg and when everything is lined up some Skip. We hardly have any local stuff left on low band here except DOT which is not monitored very often
GMB951
Cumberland Co,NC
At times my Copper J-Pole works better than the DPD Productions Omni (much better on vhf/uhf) than the omni
