VHF Marine Programming?
CDS-INC
Is it legal to program a VHF Motorola Saber II Radio with Marine Frequencies?
My father has a boat and he has an Dashmount Marine radio on the boat as well, but i have this VHF Saber Radio that i want to program and i was thinking of putting marine frequencies in the radio and giving it to my father,
Also, how would you program these frequencies?
Are the Transmit Frequencies the same as the receive frequencies?
and is there anything special that i should know before programming these frequencies into my Saber?
zz0468
Legal? Probably not. The radio would have to be type accepted inter Part 80 to be legal. I don't believe the Saber II is.
To program the Saber, you'll need a RIB, a cable, and the software. Good luck with that. Most of the marine channels are simplex. The marine operator channels are duplex.
Anything special you need to know? Look at Batlabs.com for all the nitty gritty details about programming.
ecps92
Taxachusetts
Most Commercial Radios [Part 90, are Part 80 compliant] should, but you would want to double check via the FCC [search on the FCC ID of the Radio].
Programming is probably best left to a radio shop, if you need to ask for Transmit and Receive frequencies.
Why Waste a good Sabre, purchase a marine portable for under $200 easily and it has ALL the channels, not just 12
CDS-INC
The saber i have is a 128 channel model saber, but i have an XTS5000 VHF i am using now, so i dont need the saber, i checked the with the FCC and the radio is Part 90, 136-174mhz,
what i met when i said special programming, was,
Is there anything i should know about programming marine frequencies?
I spoke with a radio shop where my father lives in long island, and they said programming a saber shouldn't be a problem, but sometimes the radio shops dont know that much about the FCC rules and Regs Vs Actually programming,
LukeB
I am curious what the output is of a typical VHF Marine Radio, both hand held and mounted. Is it 5 watts for a HH and 25 for a mounted radio with whip antenna?
ecps92
Taxachusetts
6watts / 3 watts / 1 watt on a Handhelds
25 Watts / 1 watt on typical Mobile/Ship radios
I am curious what the output is of a typical VHF Marine Radio, both hand held and mounted. I was thinking of doing something similar to the OP with a HT1250.
LukeB
In comparison, how much of a difference would it be to receive VHF Marine channels on an HT model radio compared to a Marine radio? I don't plan to do any transmitting, just to monitor.
CDS-INC
i dont think there really is a difference, they are both about the same wattage
ecps92
Taxachusetts
Depends on the sensitivity of the RX Board inside.
The Marine radios are pretty tight for the 156-162 Mhz Band
vs a Two-Way that is probably set for 148-174 Mhz
LukeB
My original thought was that the Marine radio was tuned better and even tighter like you mentioned. I guess my question may have been more geared towards anyone who has used a Motorola type radio to monitor the Marine channels.
Thanks for the feedback none-the-less.
k8tmk
Stevensville, MI
Unless things have changed over the last few years, at least the transmitter portion of the radio MUST be programmed by someone with at least a General Radiotelephone license. Also, the radio needs to be licensed by the FCC (callsign), and (again, unless things have changed) the operators need at least a Restricted Radiotelephone license.
Randy, K8TMK
hill
Middle River, MD
A FCC marine license not required for pleasure boats operating in the USA anymore. I don’t recall the exact date the rule changed, but it was around ten years ago. Pleasure boats require a marine license for SSB-HF and traveling outside the USA. Commercial vessels still are required to have the a FCC license and the operator must have at least a Restricted Radiotelephone permit. Operators on the pleasure boats cruising outside the USA still are required to hold Restricted Radiotelephone permit.
