Vhf mobile antenna.
WVFC80
PA, USA
If I'm not mistaken I think they do but on vhf your rx and tx is going to be diminished because of the antenna length/design. What prevents you from using a traditional 1/4 wave?
Yes they do, but like WCFC80 and FFPM571 say, they suck.
We have one on a fire truck, and it's got no range at all, compared to a 1/4 wave whip.
If you really need low profile, put a 1/4 wave on, and bend it back.
WVFC80
PA, USA
The only time those style antennas give any sort of performance is on 800 mhz and even then sometimes coverage is marginal.
DisasterGuy
Maryland Shore
I use Laird Phantom antennas extensively. They are the cat'a meow on 700/800 and are acceptable on UHF. On VHF they are quite large (about 5" in diameter) and their bandwidth is only about 1MHz. Unless you have a specialty application that requires minimal vertical clearance, need very minimal bandwidth and are working with a very strong system they wouldn't be advisable.
An option if you want something that blends in is the Sharkee. We have had pretty good luck with them and you get a lot of use out of a single roof penetration. http://www.sharkeenow.com/
