VHF noise when inverter is on
yorkphotog
Toronto, ON, Canada
I've recently completed an install on a 2012 Ford Escape with 10 scanners (pics to come!).
Most of the radios are running 800 Mhz trunking, but I do have a couple that do VHF (an MCS2000 and a 996XT).
Whenever I turn on my power inverter (with any sort of load), there is interference in the VHF radios. The power inverter is powered from a separate wire directly from the battery. All of the scanners and other gear are also on their own wire (going through a DC fuse panel).
I'm thinking possibly bad ground on the inverter..? The inverter is in the back of the car and all of the radios are up front.
Once I have some time it will go back to the installer for more investigation...
Any ideas..? Thanks! :)
LtDoc
Oklahoma
A bad 'ground' is one possibility, but there are others. Probably the most common is that inverter is radiating RF. The 'cure' for that is shielding (enclosing all that RF), or routing it to ground by by-passing it (inside the box). Some inverters are just noisier than others, usually because the manufacturer didn't do an adequate job of 'filtering' the thing, probably didn't figure on it powering something that was RF susceptible. Because of how they work, inverters are terrible noise generators to start with. It is NOT a simple thingy to clean up, and usually why the 'better' ones are more expensive.
Good luck.
- 'Doc
yorkphotog
Toronto, ON, Canada
Thx!
I should also mention -- the inverter is a Xantrex ProWatt SW1000 (true sine). I had the 600w version in my old car with no issues...
I just took a closer look at it and realized the "CHASSIS GROUND" terminal on the inverter isn't connected to anything. :p
yorkphotog
Toronto, ON, Canada
Nope, not resolved yet. Just haven't had time to work on it. :)
It is indeed like a white noise static that covers the audio the second you turn the inverter on.
If anything is plugged into the inverter, the static is even worse.
The inverter is run on a separate 0 gauge wire from the battery straight to the inverter.
bikinjohn
Las Vegas, NV
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROIDX Build/4.5.1_57_DX8-51) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
You may want to try a power filter on the radio's power, they're not very expensive. Maybe that'll work
yorkphotog
Toronto, ON, Canada
Sadly it seems like it isn't necessarily the inverter causing the issue.
Even when my Toughbook is running via battery power, it is causing obvious interference in the VHF stuff. I'm also thinking power issue...?
