I've recently completed an install on a 2012 Ford Escape with 10 scanners (pics to come!).
Most of the radios are running 800 Mhz trunking, but I do have a couple that do VHF (an MCS2000 and a 996XT).
Whenever I turn on my power inverter (with any sort of load), there is interference in the VHF radios. The power inverter is powered from a separate wire directly from the battery. All of the scanners and other gear are also on their own wire (going through a DC fuse panel).
I'm thinking possibly bad ground on the inverter..? The inverter is in the back of the car and all of the radios are up front.
Once I have some time it will go back to the installer for more investigation...
Any ideas..? Thanks!
