Vhf Road Radio For Northwestern Canada
ruffy
I work in the oil and gas industry through out Alberta and Northern B.C. Many of the jobs I get called out to require the use of road radio's. Some roads it is required by law to have a radio or else you un-able to travel these roads. I have had a few radios that come pre programmed, but it seems I always end up on a job going into an area with a frequency that I don't have.
My question is this, what radio would be best suited for me?
It would have to have a minimum of 100 channels.
I need to be able to program a few channels if need be.
The best range possible 120 - 180 mhz?????
And please spare me the legalities of programming bla bla bla. I'm familiar with the laws, though I may not agree with them.
Any help would be appreciated. Thanks very much
BC_Scan
Vancouver BC
define best , I don't even know you , having a field programmable radio in Canada (for business band) is a no no, If you get caught , and you could , IC does road blocks with ICBC & MOH and I have seen the list of confiscated radio's , mainly ham radio's modded to go out of band,
100 channels will likely add a premium to the mix, however TAD raidos are a good one to check out, I believe Canadian made (not 100% sure)
the range you would want is 150-174 that is where that spectrum falls into your need
check this out
www.petron.ca/m10.html
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
You're looking for a VHF radio, which will do 136-174 MHz. Any number of devices can do 100 channels or more, most likely in banks of channels at a time (my Motorola radio supports 10 banks of 16 channels = 160 total channels).
Any half-decent radio shop should be able to set you up with a good radio. Kenwood and Motorola, IMO, are the two primary models to go for. If money is no object, you can get some pretty decently bomb-proof Motorola devices.
You may also want to check eBay, if you're willing to use a radio of unknown ancestry (i.e. you don't know where it's come from or how it's been treated). A lot of refurbished or retired radios go through the eBay route.
ruffy
Can you suggest any models in particular that I can add a frequency in the field with out having to go to a shop to do it. I know the guys that sell them have told me some are possible to do and others aren't.
Yup, and the 136 - 174 is perfect. I have an old Tad right now... It's a loaner, as my other one got ripped off. But this thing is a dinosaur with 4 buttons and only 40 channels.
I figured the no no's would come.. But as it states in my post, some of these roads require you to have a radio by law. No radio, no road. Doesn't matter if your delivering a pizza or work there every day. You need a radio.
Thanks again for your help.
robertmac
To quote: "And please spare me the legalities of programming bla bla bla. I'm familiar with the laws, though I may not agree with them". Well tough, rules are made to protect things, in this case it could very well be a person's life. This post is very similar to one on another web site about some rich oil worker that thinks he is above other people and the law. Well, not on radios.
I suggest you check with the compaines that you have to travel over their roads. A much more legal and easier alternative would be to contact them by cell phone or sat phone [which I am sure an oil field work or the oil company] can easily afford. Another alternative is to check with Industry Canada, obtain the appropiate licence for the frequencies you need, have someone program these into a Tad, Motorola, Kenwood, Icom, Yaesu commercial radio and away you go. Just follow the ristrictions on the area a frequency can be used as in other areas it may interfere with EMS/FIRE/RCMP frequencies.
Jay911
It's very rare to find a "front panel programmable" handheld with your specifications. The only one I know of is the long-discontinued Motorola JT1000, which IIRC only has 16 channels.
If you're working well sites, logging roads, etc., there are only about ten frequencies you actually need, anyway; the Logging Common (aka LAD) and roads common channels are pretty much universally used.
I, too, won't support illegally operating on unlicensed bands. If you're working for a company, or in conjunction with them, their telecoms manager can provide you with a letter granting permission to use the appropriate frequencies, and odds are he can get your radio programmed, or get you a line to someone who can do it.
