VHF/UHF/800 scanner/transmit antenna project
prcguy
Over the years I've collected lots of antennas for projects including some nice Shakespeare marine versions used on Govt vessels. I've had the parts laying around for years to make a VHF/UHF/700/800 setup using discreet marine antennas for each band and a commercial triplexer but never got around to putting it all together. Then a friend got some multiband radios and needed something similar so I gave him a shopping list of what I had not expecting him to actually find all the parts. Well he did and I just finished putting together all his parts into a really nice multiband base antenna that would be great for any scanner enthusiast or someone with a multiband radio like Motorola APX8500, Harris XG-100M, etc.
The individual antennas used are the Shakespeare HS-2774-R covering 136-174MHz with 4dBi gain, a Shakespeare US-3849 covering 380-490MHz with 4dBi gain and a Shakespeare 4800 series designed for 800MHz but covers down into the 700 range just fine. All are rated for shipboard use and should never have a problem from weather or corrosion. All antennas are mounted on a 6ft cross arm giving 1/2 wavelength spacing between antennas at VHF and much more at UHF and 800. Right below the cross arm is an outdoor NEMA rated box containing a high power Motorola triplexer and interface cables providing a single feedline to the radio. All antennas and hardware have been primed and painted grey to soften the impact to neighbors. Mast and cross arm hardware are aluminum castings from NuRail.
This setup should provide a very noticeable improvement over using a Discone or similar commercial multiband antenna. Since these antennas were first introduced Shakespeare has made a single antenna covering all the same bands (model US-1387) but its much less gain on VHF and UHF. You could do better with commercial broad band repeater antennas but a couple of 21ft tall VHF/UHF and maybe a 15ft tall 800 antenna is not going to work on a lightweight cross arm or fit on most residential roofs.
Anyway, here are pics of the antenna system and triplexer box set together for the first time and it all has to come apart to transport to its final destination. The 10ft mast holding the cross arm is the top piece of a home made 20ft pushup mast that will affix to the new owners chimney with a heavy duty chimney mount.
I have a duplicate set of all parts and someday will put together the same setup on my roof to replace an existing Discone with supplemental 700/800 antenna with diplexer.
Looking at the options that the big antenna manufacturers have for multiband base antennas, I think you could make a lot of money if you had someone to market them. The offerings from the companies I've looked at are in the $1,500 and up range.
prcguy
There are other options. I'm currently helping an organization installing some of these for interop. (1Y20850) MADP150-450-816 - Hascall-Denke
I've looked at their antennas a few times. They usually have a pretty interesting booth at the trade shows showing off their military antennas.
prcguy
@prcguy how do you compare this approach to the build you did in this thread prcguy's mast mount filter/preamp/diplexer thingee
The mast mount filter/preamp/diplexer was to make use of a Discone and originally intended for receive only but I did put in some bypass relays so I can transmit at low power. The marine antenna setup above is much better for transmitting as the antennas have more gain than a Discone. For receive only the marine antenna setup is very good minus any preamps which helps driving long runs of coax. But since the marine antennas have some gain over a Discone it can work better than the filter/preamp/diplexer in some receive only applications.
VE2XWA
Montreal, Quebec
I'm also working on a project with a Hammond box. Nothing complicated, just a cable in a box big enough to hold an amp, batteries, etc. Outside access to my shack to test / try a temporary antenna.
prcguy
Update to this project, got all the items to the new owner and the mast with cross arm, triplexer and all antennas are mounted to his chimney using four SS strap mounts provided by the owner. All connectors are covered in hot glue heatshrink and the 20ft pushup mast is nested in the picture below. It will go up another 8ft or so and we decided to add guy wires when the job gets finished next week.
LMR400 will be run into the attic to a two way coaxial relay then to a radio in the house and to another location in the garage where the coaxial switch will be energized by the garage power supply when that radio is on. This setup will provide noticeably more gain from 136 to about 870MHz than any Discone or triband or multiband antenna I know of. I might post a picture next week with the pushup mast extended and guy wires installed.
lucas2121
Sorry about hijacking your thread, but there seems to be a lot of knowledge here. I've learned a lot from all of yalls posts over the years.
I've got a Motorola EQ000103A01 that I'd like to use to conjoin two XPR5550e radios, one being VHF and the other UHF to a single dual band antenna. I wanted to confirm the Motorola EQ000103A01 would accomplish this and allow me to monitor and occasionally transmit with both radios at the same time without damaging one of the units. I've seen some cheaper hammy options, but this seems more robust. Also, this unit is listed as low power, however I can't find a max wattage anywhere. Obviously with the 5550s it won't see beyond 50 watts, I just wanted to reaffirm this will work before I order adapters and take this out of the packaging.
Thanks in advance.
prcguy
Thanks in advance.
Yes and it should handle at least 50w as the APX8500 it’s used with puts out that much on VHF and a little less on UHF and 800. It’s best to termite the unused port with a 50 ohm load and a 1/2w load should be fine.
lucas2121
Thank you for your quick response. Combining antennas is something new to me, I'm limited on real-estate now. Is there anything you would recommend better than this for my application?
I had thought about using the third port for a 7-800 scanner, (adding a discone or triband) however I would be concerned about damaging the scanner. That said I assume it just wouldn't pass audio outside of the third band and it would be a moot point.
prcguy
If you just need to combine VHF and UHF there are much less expensive diplexers made by Comet and Diamond. What exact frequency range do you need in each band?
lucas2121
144-162, 440-470. Main transmissions will be on 158.xxx and 460.xxx, mostly monitoring the others. I got these for around $50 a piece. I keep reading mixed reviews on the Comet and Diamonds. By the time I add adapters and jumpers though, those may be cheaper.
