In addition to the Xmas tree stand, I was using an 18’ telescoping aluminum lightbulb changing pole. I used a pvc coupling where the ID was the same as the OD of the pole and the OD was the same as the ID of the stand. Had it up about 5 months all over the property to find the best location for a more permanent antenna. Was using a Larson triband with a base station ground plane converter. Worked pretty well in high winds too though I’d recommend adding a 25 lb barbell weight at the bottom. Wife nicknamed it “The Monstrosity”.
