Viewing Radio ID's on recorded audio
nosoup4u
High Bridge, NJ
I often do some recording in order to identify radio ID's on trunked systems (x36 models). The radio id's will show during playback, but if I record a lot of audio, that is time consuming to go through.
Anyone know if it is possible to pull the ID's out of the wav files? If I look at the file properties, I see the system and talkgroup info, but nothing on the radio ID's. I have tried a few different ways to view the extended properties but I haven't had any luck so far.
rjdj2000
Gone Cuckoo
Central NY
No problem.. Tried it myself with my 536 wav files and it worked fine. If there is a lot of audio files it takes awhile but it does work.
