2.92 it looksYou can submit a name and DB Admin will decide if it is right, I'd suggest either HAYESVILLE or CLAY County, since that is the location. What is the site number, SDS should show you the info.
Based on other sites in the DB; I think that 92 would be the number?Not sure my BCD325P2 shows 01FCh-0292 when resting on the control channel.
Nope that one is taken.Based on other sites in the DB; I think that 92 would be the number?
Make sure it is being used, not just tested, before submitting. CC and other info may be different when testing.It is possible that site numbers have switched while they bring more online. I'd go off of what the scanner says before the potentially outdated database.
| Talk Group ID | Frequency | Tone | RSSI | UID | Mod. | Hits | Duration | Start Date / Time | End Date / Time | System / Site | Group | Channel | Number Tag Tune | |
| 52200 | 771.8437 | 471 | NFM | 6 | 00:00:52 | 04/19/23 17:33:14 | 04/19/23 17:36:05 | WRTE451 | SHP TROOP G | DISTRICT 6 |
I live in between the two towers, and they are working fine using a BCD 996P2Hello VIPER gurus. I'm having trouble picking up the Fayetteville TWC site with my BCD536HP w/trusty RS800 from northern Robeson County. Is there any beamforming or something going on with these sites? I would think I'd be able to get it no problem. I can even receive from the Slocomb site, so I wouldn't think distance is an issue. I did realize that the Fayetteville TWC site is 700 vs the other sites in the area being 800. Does the RS800 suck on 700? Thanks!
Getting them here still in Hayesville:Not sure what happened, but I was receiving group 6 of NCHP on my Pro-2096 with no real issues. Then I noticed that I would receive them for a few days, then it would be silent for a few days. Now I have nothing at all. I do receive other agencies. Murphy NC area.
Ok. Still not sure what happened as to why I was, and now am not. I guess I will do another check to make sure I have what you show in the picture loaded into my scanner. Thanks!Getting them here still in Hayesville:
Check to make sure all cc and alt cc are in the scanner in case they are temporarily using one of the altsOk. Still not sure what happened as to why I was, and now am not. I guess I will do another check to make sure I have what you show in the picture loaded into my scanner. Thanks!
CC for Murphy site:Thanks. I have done that numerous time since I have had the issues, and I have them all, plus the ones that are not listed as cc in RadioReference. But I am going to go back one more time. But still seems strange it was working, and then just stopped without any changes on my end. Back to the beginning, I guess.
Yep, I have that one programmed in. It is not locked out.....so....CC for Murphy site:
Could your problem be talkgroup related? Is the talkgroup locked out?Yep, I have that one programmed in. It is not locked out.....so....
I don't believe so, but I am going to check it again. I also will make sure that I have the talk group you showed programed in also. Thanks for the all the help.Could your problem be talkgroup related? Is the talkgroup locked out?
I just finished checking out what I have programmed, and found the talk group 52220 was not in my scanner. But, what is confusing is I do not see this talk group listed in Radio Reference for NCHP. They do list 52202 as the talk group for Troop G District 6 Cherokee County, which I did have programmed. I also have the following control channels programmed: 853.8375, 853.3250, 853.7625=Joanna Bald, and then 852.200 for Murphy as per Radio Reference.I don't believe so, but I am going to check it again. I also will make sure that I have the talk group you showed programed in also. Thanks for the all the help.
My photo shows Talk Group 52200 but sometimes the display will indicate 52202 also. I believe this is because all Troop G traffic is dispatched out of Newton. I listen by unit numbers to tell where the traffic is from.I just finished checking out what I have programmed, and found the talk group 52220 was not in my scanner. But, what is confusing is I do not see this talk group listed in Radio Reference for NCHP. They do list 52202 as the talk group for Troop G District 6 Cherokee County, which I did have programmed. I also have the following control channels programmed: 853.8375, 853.3250, 853.7625=Joanna Bald, and then 852.200 for Murphy as per Radio Reference.
I will give it a few days and see what happens now. Again, Thanks to all. These Viper settings are new to me, so I am trying to get it figured out.
