jimf
Is anyone using this device to monitor STARS. If so, can you summarize your results.
Thanks,
Jim
Thanks,
Jim
I may have to check my antenna.....even did an ANALYZE and couldn't find a signal. Time to drive to Abingdon with the mobile,I guess.VA STARS is still active. I have had hundreds of calls on the VA STARS 150MHz trunks today alone. They are not encrypted, but they are P25 version 1 trunking and cannot be heard with an analog scanner. They have some analog VHF low-band and SIRS channels, but I do not really listen to them, and they are only infrequently active from what I am told.
When I had my HP2,5 years ago I could get VA STARS. Now with my BCD536HP.......tried it tonight...07/18/21. No Luck. I'm in the Elizabethton,TN/Bristol,VA area. Do not know what has changed. Any ideas,anyone?
Yeah.....about a week ago.Make sure you have a fairly recent update from the database in Sentinel.
Deleted? They are officially encrypted or moving freq's? Miss listening to their traffic. I could usually get them from the Abingdon site.
STARS isn't fully encrypted and most of state police is currently clear, unfortunately they're in the process of replacing all their radios to the APX series and upgrading the system. They plan to go full time encrypted once complete.
That's the first time I've seen that they plan to go fulltime encrypted. Has that info been posted in the Virginia forum?
