jrrob8
just got my 536 yesterday, every FL I programmed has worked perfectly, except my Va state police. seems to be correct but does not work. anybody have a suggestion?
When you say "shows signal", do you mean that the scanner stops scanning and lands on a channel and the signal strength indicator shows a few bars, but you can't hear anything?
Turn off the FL, turn on the main dB and put in your location (zip code) then set range to 0. when it is scanning that system, press SYS to hold on the system.
Make sure the appropriate service types are enabled.
have done everything you suggested and it is ID searching. have 5 bars of signal, but it is not receiving. Have checked all the freqs and Id's. still no luck.
since nothing seems to be working I might try and a new favorites List.
