Virtua Memorial Hosp
philacop
Clifton Hgts PA
Anyone in the Burlington County area know if Virtua Memorial Hospital are still using 502.4375 for security?
I have not heard anything in quite some time. Its the Mt. Holly campus
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
If you have it programmed in as a memory channel with DPL tone, try plugging it in manually via quick search to see if they changed tones or operating modes. I'm seeing DMR emissions for that frequency on their license. Maybe they switched to DMR? Might be worth checking the other "FB" frequencies listed on the license for activity as well
Whiskey3JMC
Philly burbs 🇺🇸
Looking at their FCC ULS entry, it appears a modification was made back in July adding the aforementioned DMR emission to this frequency. This confirms my assumption that they moved to DMR
76796
philacop
Clifton Hgts PA
Don't think so as the other campuses are still analog and were heard this month.
I hear them on there maint channel and its analog with same dpl, (463.725)
They are licensed also on 463.250 but again have not heard anything on that frequency at all.
What color code do you have for 502.4375?
Could be part of a connect plus system
Whiskey3JMC
Philly burbs 🇺🇸
As I said it's only my assumption that they moved to DMR. If they were a part of a connect plus system their radio service would be "YG" instead of "IG". Capacity Plus maybe?
philacop
Clifton Hgts PA
I just checked the FCC database and there are no connect plus systems in the area on that frequency.
I mistook you thinking you were receiving a dmr color code,
