Need help, Program will red and wright to scanner; however when opening the virtual control no usb port is listed & unable to detect a port.
Thanks in advance for your help.
Hi Gommert- any idea how to install the drivers? I’m an IT guy with a lot of computer experience, and this is making me feel like a fool.For virtual control you need to install the USB drivers , they can be found in the ARCPATROL folder under Program Files\Butel\ARCPATROL
Gommert
www.butelsoftware.com
Did you locate the drivers in the..... Program Files\Butel\ARCPATROL folder?Hi Gommert- any idea how to install the drivers? I’m an IT guy with a lot of computer experience, and this is making me feel like a fool.
Thanks!
yes- no issue locating them. In Device Manager, the HP2 is USB Mass Storage Device in the list- it comes and goes as you plug in and unplug so it's the right device. When you try to update driver, it squawks that the driver is not 64-bit compatible.Did you locate the drivers in the..... Program Files\Butel\ARCPATROL folder?
Disregard- I am Lord of Idiots. You need to run HP2 in Serial Port mode for Virtual Control, not Mass Storage like you do when programming. The driver for serial port was updateable. No instructions anywhere that I can find...yes- no issue locating them. In Device Manager, the HP2 is USB Mass Storage Device in the list- it comes and goes as you plug in and unplug so it's the right device. When you try to update driver, it squawks that the driver is not 64-bit compatible. View attachment 134076View attachment 134076
Spoke too soon. Driver updates, but ARC Patrol immediately goes to NOT RESPONDING and hangs when HP2 is in Serial Port mode and right com port is selected. Windows 11 PC. Rebooted, checked everything, it hangs every timeDisregard- I am Lord of Idiots. You need to run HP2 in Serial Port mode for Virtual Control, not Mass Storage like you do when programming. The driver for serial port was updateable. No instructions anywhere that I can find...
-This is my consistent result for virtual control in serial mode,
it does, after the driver update. But virtual control won't show the com port unless I physically disconnect and reconnect the scanner, and then it comes back. May or may not start virtual control, but then soon goes to Not Responding. This is a healthy, generally very stable PC.-
Does Windows Device Manager show a "Uniden Serial Port COMx" under Ports (COM & LPT)?
I'm not certain, but I think you have to have the Extreme Update installed for virtual to work.Need help, Program will red and wright to scanner; however when opening the virtual control no usb port is listed & unable to detect a port.
Thanks- I do have the Extreme Update installed, but not sure if that actually is a requirement. I would like to try it on a machine other than Win11, may attempt that next. I use Butel virtual control on other scanners and I am a fan.I'm not certain, but I think you have to have the Extreme Update installed for virtual to work.
-But virtual control won't show the com port unless I physically disconnect and reconnect the scanner, and then it comes back. May or may not start virtual control, but then soon goes to Not Responding.
