BOBRR
Hello,
Three questions please:
Using a Uniden SDS 200 with a relatively new W10 pc
a. Have been playing around with the Virtual Control with ProScan, and also with
Butel ARC 536 PRO.
After all sorts of problems, due to my ignorance, with the COMM Ports, have finally gotten both
to function. I am very reluctant now to change anything, but I think this is probably a
valid concern. Seem as if the Unit to pc comms isn't all that it might be regarding speed.
The BAUD Rate is now set at 9600.
Should I try higher BAUD rates ? What's a "good" and appropriate number ?
Any other setting under the COMM Port settings in the W10 Device Manager that I should perhaps also check ?
b. I know ProScan has this option, but is it possible to implement the unit to pc communication
via the LAN/Ethernet Port on the SDS 200 with Butel ARC 536 PRO ?
I understand if done this way, the audio will also be piped to the pc, which would be helpful.
Any other advantage, such as speed, or... ?
If so, how to do it, please, and what settings, etc. ?
Really explicit how-to would really be appreciated. Not too sharp with this "stuff" anymore.
c. And, irrespective of the above, can I take the headphone output from the SDS 200 and plug it
into the pc so I can use its speakers ?
What pc plug would I use ?
Any potential grounding problems, etc. ?
Much thanks,
Bob
Butel ARC 536 PRO.
Much thanks,
Bob
