OP25 VirtualBox Project - Run OP25 on Windows 7
BigRedBox80
It signifies that tgid "12105" and tgid "12152" were both seen active on voice frequency 856.462500 as recently as 13.9 seconds ago. The last entry on the line is a count of how many times that voice frequency has been active.
Thanks, that's what I wondered.
I'm almost certain I'm still getting audio from 3071, even though it's on my block list. Am I missing something?
boatbod
Talbot Co, MD
You can prove that fairly easily by setting the log level to "-v 1" and running some traffic. First of all "3071" should appear in the list of tgids blacklisted when the application loads, then once it's running traffic you will see a "voice update: tg(xxxxx)" message for every voice call that is tuned. If you have successfully blacklisted 3071 it will not appear in a voice update log message.
maus92
The OP
I have this extremely long blacklist cell in my trunk.tsv file, with tgids separated by commas. Awkward looking, but it works. When a new ENC TGID transmits, I insert the tgid in the list, save the trunk.tsv file, then restart op25. No readout of the excluded tgs, but it works, and it's fast.
boatbod
Talbot Co, MD
That's a very clunky way of doing it. In my view, the ability to list blacklist tgids in a comma separated list inside trunk.tsv is deprecated. It's better to list them in their own blacklist file as described above; easier to edit, more features (i.e. ranges), less likely to screw up trunk.tsv formatting.
maus92
The OP
Yea but I have to hand edit a new file - I’m too lazy for that.
Yea, but that would require manually editing a new file. I'm too lazy for that.
