Visar Scanning?
landonjensen
Area C
How do i pick what channels i wanna scan on my visar? I cant figure it out, yet i know its capable of it.
Any help?
gatekeep
FAIL 01/93
New York, NY
Only /\/\ radios I'm aware of that allow user end programming of the scan lists, are those with limited or full keypad's and displays... Both of which the Visar doesn't have. (The 2 digit channel display doesn't count.)
txshooter
Texas
You can easily program your own scan list on the fly with a HT1000. It's all in how you program the radio initially. Most agencies did not want users to be able to program thier own scan list so that was not enabled.
It's been a long time since I fooled with Visar's, but they are nothing more than a HT1000 with the board foled in half. May or may not work........
Note the HT1000 and Visar are even programmed with the same software.
landonjensen
Area C
Yup, mine is on the ABC Switch the and the green button on the side, so I can program the scan list right there. :)
N4DES
Retired 0598 Czar ÆS Ø
South FL
Except that the visar doesn't have an ABC switch and there are only 2 side buttons plus the PTT. I have seen the option in the RSS but was never able to firure out how to have enough buttons to do the function after I assigned the blue one as the light and the other as monitor.
