Visiting La Quinta, Coachella, Indian Wells area
spicerz
Colorado, Arizona, California
Hello everyone. I'm programming my PRO-197 and I'm somewhat confused. I've establised that most of the desert cities out here are dispatched by RCSO but I don't see any talkgroup ID's labeled RCSO on the desert system. I only see Palm Desert Primary and Indio Primary. Are those two seperate primary dispatch talkgroups for RCSO? If I'm correct, what cities does PD primary dispatch and what cities does the Indio primary dispatch? Thanks.
rolncode2892
Palm Desert and Indio are separate dispatch channels for RSO. I believe La Quinta and Indian Wells are both dispatched on Palm Desert. Coachella should be on Indio primary.
brandon
SoCal
La Quinta and Coachella are on Indio Primary. La Quinta deputies have "L-A" callsigns and Coachella are "Young" units. Indian Wells uses Palm Desert Primary and identify as "John" units. Sometimes both channels are patched together, so you may hear everybody :)
Indio PD uses 158.730.
County Fire is dispatched on RRU 3 which is 151.130
For Coachella and Indio areas the fire response channel is Support 10 on 154.755
The Indian Wells and Palm Desert side they use Support 12 on 154.800
