Vista, San Diego Co. Help
N8DRC
Grass Lake
Hi
I need a little help, my Aunt lives in Vista (San Diego Co.) and she has sent me her scanner to program for her it's a BC296D and I live in Michigan, I already have the BC296 and am very familier with it, I just need help on which frequencies to program in for Vista..Should I just put in the San Diego Co trunking frerquencies, she would like to hear the PD,FD, and EMS..Any help would be appreciated..Thanks.
brandon
SoCal
Vista Sheriff Dispatch is on the RCS North Site. Here are frequencies and talkgroups.
http://www.radioreference.com/modules.php?name=TRSDB&sid=499
Also on the north site: Carlsbad PD/FD, Escondido PD/FD, Oceanside PD/FD, San Diego Sheriff (San Marcos, Vista, Poway, Rural, Encinitas), Rancho Fire, North County Fire Talkgroups/Mutual Aid/Law Command and tacs, and a lot more.
If you want I can send you the file for San Diego since it will make programming much easier than starting from scratch. I have everything in separate banks for the RCS North and South (SO, PD and Fire) as well as SD City (PD and Fire).
N8DRC
Grass Lake
If you could send the file that would be great..Thanks Brandon..
If you want I can send you the file for San Diego since it will make programming much easier than starting from scratch. I have everything in separate banks for the RCS North and South (SO, PD and Fire) as well as SD City (PD and Fire).[/quote
bhesson
Alpine, Ca.
Maybe you could attach the file on a post for all to enjoy?
brandon
SoCal
Here ya go... this is the file I use when going down to SD.
I have the RCS East programmed but not sure if the right talkgroups are in there. I am not able to monitor it as much as I'd like, so maybe someone else can confirm.
