N4GKS
I've never had as much trouble with a software not wanting to load. Gets so far then it says Windows service installer error. I've tried patches, SP1 and everything else. Any ideas?
Open up Windows explorer and navigate to the iScan executable file. Right click the file select Run as an administrator. Vista should prompt you to run as admin then execute the program. If you get the same error then most likely your iScan CD-ROM is corrupt. You can ask for a replacement at RS or borrow a friends.I've never had as much trouble with a software not wanting to load. Gets so far then it says Windows service installer error. I've tried patches, SP1 and everything else. Any ideas?
Thanks.There should be a tab labeled "Trunked Radio Systems" along the bottom of the program's main window. If you don't see that tab, make sure "Simple Display" on the "General Settings" tab is set to Off.
Thanks. If I want to delete everything in playlist 1 can I do it on the scanner itself? If so how is it done?There should be a tab labeled "Trunked Radio Systems" along the bottom of the program's main window. If you don't see that tab, make sure "Simple Display" on the "General Settings" tab is set to Off.
Great help. Thanks. I think the only real shortfall of this scanner is the fact that you have to have a card reader to load the softawre. Not everyone has a reader and every trunk scanner made in the last 10 years is programable with the cable. Strange this was not done the same way. Only one of the trunk frequencies that are in my area was good and of those you only need 4 control channels not the whole list that RR has. I supplied RR with those 4 but they have yet to be updated on the download from them to this scanner. The card also has the wrong/old frequencies in it.There is a section for this in the Pro-107 wiki....
Pro-107 - The RadioReference Wiki
I just went through and added section headers to make it a bit easier to find a topic
73 Mike
It's not so strange if you consider this: if you only used up one quarter of the available space in the scanner, it would still take you more than 24 hours to transfer the data over the cable.Great help. Thanks. I think the only real shortfall of this scanner is the fact that you have to have a card reader to load the softawre. Not everyone has a reader and every trunk scanner made in the last 10 years is programable with the cable. Strange this was not done the same way.
Does the RR DB show your corrections (i.e. in your web browser via the "Database" link at the top of this page)? If so, when did the corrections actually appear in the DB? The PRO-107's database is updated every Saturday morning... have you verified that you have the most recent version (you can update it from within the PC app)?Only one of the trunk frequencies that are in my area was good and of those you only need 4 control channels not the whole list that RR has. I supplied RR with those 4 but they have yet to be updated on the download from them to this scanner. The card also has the wrong/old frequencies in it.
