VLC doesn't work
smithken
Michigan
Scanner: BCD536HP, firmware 1.05.01
Wifi dongle firmware: 7.28, IP address: 192.168.1.180
VLC version 2.20 on both Mac Yosemite and Windows 8.1 64 bit. Windows is on a real Windows machine, not a virtual machine.
When I try to open rtsp://192.168.1.180/au.scanner.au I get a message from VLC "Your input can't be opened VLC is unable to open the MRL 'rtsp://192.168.1.180/au.scanner.au'. Check log for details". When I check the log a couple things get my attention: "main debug: no access_demux module matching "rtsp" could be loaded" and "access_realrtsp warning: only real/helix rtsp servers supported for now".
I have turned off the firewalls in the computers and I have tried setting the scanner as an access point and then connecting directly to the scanner, I get the same results. I have also spent a few hours searching this forum and the web for help and found nothing.
mitbr
Tampa Bay Florida
Are you loading into the right place in VLC should be Media then open stream ?
Tim
W4ELL
Maryville, Tennessee
Unless you just mistyped the URL in this post, it is incorrect....
Use:
rtsp://192.168.1.180/au:scanner.au
smithken
Michigan
No I didn't mistype anything, at least not in my post, I must have checked that 4 or 5 times too and still missed the colon.
UPMan
In Memoriam
Arlington, TX
Your post has au.auscanner.au
The correct is au:auscanner.au (a colon instead of a period the first time).
jwheatley
Middletown, IN via Kokomo, IN
I've done the samethings described in this post and still cannot get VLC to work.
I also can't install the remote software as I get the attached error. I am using an Administrator user and have updated firmware on the scanner and dongle.
Any help would be appreciated
ProScan
Software Provider
Ontario, Calif.
It looks like VLC can't start up. It looks more like a Windows thing. I would re-install VLC in a new folder like C:\temp and try it again.
UPMan
In Memoriam
Arlington, TX
You are trying to run RH from a system temp folder that normally is deleted on power cycle (and maybe other conditions will make the OS delete the files). You need to put the RH...exe file in a "normal" directory.
