Vlf receiver (wilfried fritz design)
dr_peppers
Hi Guys.
Not exactly lw, this is very long wave.
I built a version of wilfried fritz's Vlf receiver as found on vlf.it, I dont know if anyone here has any experience of one of these.
I'm finding it difficult to get the thing to work, I got the Lo to oscillate from around 400kc to about 650kc, so thats ok, then I tuned the Bfo so that the ceramic filter will pass it and generate a tone on receiving a Cw signal.
I also checked the audio bandpass filter with my sig gen, it performs as expected.
I used a J310 in place of the Bf966, and biased it slightly differently.
The problem is the circuit is as deaf as a post, I eve took the thing out in the fields to try it, same difference.
Anyone else any ideas.
Yes I'm new here.
majoco
Stirrer
New Zealand
Welcome to the forum, we'll help you all we can, but....
In no way is a J310 equivalent to a BF966 regardless of how you bias it. A BF966 is an insulated gate mosfet and has an extremely high input impedance which is why you should get good VLF reception on just a whip antenna. I suggest you try to get the right part and have another go - by the sounds of it, you have the rest of it working correctly so it shouldn't be too far away.... :)
dr_peppers
Hi,
You might be right, however a bf966 isnt an ignt, according to its data sheet its definately a fet, the major difference with it and a J310 is that the Bf device is dual gate, however one of the gates in grounded in the application anyways, the only other difference which may make a lot of difference is the gate source capacitance is double, I can compensate for that on the preselector, and were talking vlf not vhf.
I'll have another look at the datasheet for the J310, and maybe order some Bf966's.
dr_peppers
Ok so I'm a bit of a numpty.
I had pin 1 and pin 4 of the 455 kc filter module backwards, so the input went to the ground terminal and ground went to the input terminal, I should have wondered why there was a null at 455kc instead of a peak.
Now when I power the rx I get something, and it picks up my sig gen on 100kc across the bench.
However if I connect the Bfo the thing goes deaf as a post, I tried tuning the Bfo a little as the Bfo freq on this rx is critical, but its still as deaf as I am.
I think the o/p level of the BFo is so high its sending the agc into low gain.
Heres the page for the Rx I built:
http://www.vlf.it/fritz/pocketrx.html
Heres a vid of it:
https://www.youtube.com/watch?v=1aK_zNxkfuY
And heres another design I found that is similarish only Hf and dual conversion:
https://www.heinzstampfl.ch/wp-content/uploads/2015/03/junior1_assemblyguide.pdf
