VM8000 - Power Ratings
jeffycc
Nashua NH
Any idea on what the power outputs are for UHF / VHF and 7/800 for the new VM8000?
VHF 5/50 watts
UHF 5/45 watts
700 2/30 watts
800 2/35 watts.
That's from the preliminary spec sheet released earlier this year. I've heard rumors of a high output version that would probably do 100 watts on VHF/UHF, still 35 on 800.
KD2GSW
I am interested to see if the high power units on VHF/UHF still do DMR or if its like the NX line that don't.
AF1UD
I'd also be interested if 2-3 can be controlled via a single head... like the NX-5K series.
wd8chl
So, a high power version has not been anything more than a rumor at this point, guys.
As to the multi-deck thing, I know I saw it would work like the VM-7000, in that you could have up to 4 decks on one head.
Yeah, that means you could slam 4 of these onto one head. Or two heads. Incl. the handheld controller. Yikes...
I think it's a bit more than a rumor at this point. I've seen specifications being discussed by people I'd trust on the matter.
Yeah, yikes is what I'd exclaim, also. I can imagine the capability of a couple of these RF decks stacked and properly programmed. A lot of possibilities there for the right application.
From the preliminary VM8000 spec sheet:
Single or Dual Remote-Mount control heads (KCH-19VM, KCH-20RV, and KCH-21RVM) or Single Dash-Mount control head (KCH-19VM)
Single-Deck Multi-Band operation or optional Multi-Deck operation (up to 4 RF Decks)
