Voice Announcement
rescue674aa
I’m an idiot
Virginia Beach, VA
I am trying to find a website that's great for making voice announcements with and convert them easy to MVA file for a apx 6000.
rescue674aa
I’m an idiot
Virginia Beach, VA
I have tried it but every time it says failed. I am lost on how to do it if someone has step by step would be help or email me.
N1GTL
CT
I downloaded a free screen recorder, created a voice file and go through the conversion process and posted the video on you tube. Sorry for the quality but I didn't have time to figure out all the settings and I wanted to get the instructions up asap.
https://youtu.be/Das9WsZMAmQ
N1GTL
CT
I've been using goldwave. Works perfect.
I've heard of that but since I've been an Audacity user for a while, I use that. I believe you can batch process the files in gold wave to do them all at once. I'm not sure if Audacity offers that.
N1XDS
ÆS Ø
When I click on compress it pops up an error message stating no voice files found check voice.txt? I followed the instructions in the above video.
N1GTL
CT
As demonstrated, it worked fine. Is your voice file longer than the 3 second limit? You will get that error message if the wav file does not meet the settings requirement. The APS CPS will not see the file even though it is there because it doesn't meet the criteria. Right click on the wave file and check the properties. Make sure it is 16-PCM and 8000hz.
N1XDS
ÆS Ø
I'm using the Astro P25 CPS for my XTS 5000. How do I assign the voice announcements to the frequencies I have for my code plug?
N1GTL
CT
Curious as to what you used to make your screen capture ?
A free program called "Icecream Screen Recorder". Free version, 5 minute max which is why I went fast. I didn't spend much time to test quality as it was 11:00 p.m. and I just wanted to get the OP the instructions quick.
N1GTL
CT
I don't have the Astro software loaded on this computer and will be on the road working for a couple days. I'll check after but maybe someone else will chime in.
Did you successfully make the voice files? If not, PM me your e-mail and what you want the announcements to say and I'll try it and send them to you to see if it works.
N1XDS
ÆS Ø
I got all the voice files added. One of the wav files didn't work so I had to re do it and now I have all the voice files added to my radio. I appreciate the help! :D
