Voice Announcement
K4RMN
Make them yourself with a microphone, or use a text to speech program such as here: https://ttsreader.com/ and record the output using Audacity with the proper format as listed in the CPS. (wave file, mono, 8khz, etc.)
N1GTL
CT
The wav file works on XPR series but if you are referring to APX radios, you need to run them through the voice conversion utility built into CPS
N1GTL
CT
I'll add that since I made that video, I downloaded a program called GoldWave. I had a customer where I created 385 voice files. You put all the files to be converted in a single folder and it will run them as a batch process. If you have a lot to do, I'd recommend that versus Audacity. It is $45.00 beyond the trial period but it processed those 385 files in about 15 seconds where manually doing them in Audacity would have been 8 hours of work.
