I have DSD+ FL set to Per-Call Recording in the output settings, and in the control settings, I have voice/data call following selected, set high priority override for new talkgroups, and normal handling of both group and private voice calls.
With these settings I am obviously getting all the voice transmissions received saved as an .mp3 file in on my harddrive. This is filling up my harddrive quite a bit, and every so often I have to purge the files to free up space. I'm really only interested in recording the activities of new, or rarely used talkgroups, as I run the system all day and night and would like to be able to go back and listen to just those transmissions.
1 - Is there a means to automate the purge of recorded files ... either by setting a size limit or holding period expiration (ie set a number of days to maintain, and on startup for instance, remove any days worth of recordings older than that threshold?)
2 - Is there a means that I can record only certain talkgroups, or avoid recording certain talkgroups, so that only those new or rare talkgroups are recorded when active, rather than filling up the drive with lots of redundant information
