voice encrypted alg enhanced privacy
mikewazowski
Forums Manager
Oot and Aboot
The voice is encrypted as you already seem to know. Unless you have the encryption key used to encrypt the signal, the voice will never be clear.
And no, we cannot help you figure out the encryption key.
gafouri
hello
MikeOxlong thank you for your reply!!
the keyID=9 is'nt the encryption key used to encrypt the signal ??????
thanks
KevinC
Other
Home
hello
thanks
The key ID tells the radio which key in the radio to use.
It wouldn't be very secure if the actual key was sent over the air.
gafouri
hello
KevinC thank you for your reply!!
there is a solution to decrypte ?
I can pay for the solution
tnanks
jonwienke
More Info Coming Soon!
VA
If there was a solution, it would defeat the purpose of the encryption--rendering the transmission unintelligible to everyone except the intended recipient(s).
The only way to decrypt the transmission is to get the key from the source of the transmission. Unless you are part of the agency/entity, you will never get the key.
gafouri
hello
jonwienke thanks for you replay!
the wifi has a encryption key used to encrypt the signal, but may be decrepted !!!!??
I own a dp3401 device that belongs to the entity, how I can get the key
thanks
kayn1n32008
ØÆSØ
Sector 001
You can't recover the key from the radio you and the entity own. You need to be given the encryption key, and then load said key into the radio. You can not read the key out of the radio.
Sent from my SM-G870W using Tapatalk
mikewazowski
Forums Manager
Oot and Aboot
thanks
You can't.
Continuing this thread is really pointless.
You must accept the fact that you will never be able to listen to them.
